2oldman
Apr 10, 2018Explorer II
mike-uswest wrote:Combiner boxes are not needed in series, you just have one 2-conductor wire spanning the panels. Yes, you'll need a controller to handle the higher voltage.
If I wanted to go series to get max use of the panels, could I put one of the AM solar combiner boxes in and go pos to neg in the box to get series with the three panels, and I would have to go to a MPPT controller?
As to its worth, probably not great with 360 watts, but if you go higher it's almost a must. If you get the parallel operation going, check for heat buildup at all connections during max solar output.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
