MrWizard wrote:
SSD is basically Erom memory , just like a u s b stick Flash drive
Ok there are electrical difference between old style Erom and newer Flash
But the basic principles are the same
Apply a charge write the data, data stays until you deliberately change it
Failure time is like the RAM in your pc, it lasts a lot longer than the mechanical hard drive, there is no physical wear, the only contributing factors are voltage and Heat, keep it cool, it will last longer than you care to keep it
Do you mean EPROM? (from what I know, EROM is an older term for EPROM). EPROMs can't be erased on a cell by cell basis, the whole thing is erased at once (requires exposure to UV light).
FLASH memory used by USB thumb drives and SSDs evolved from EPROMs but differ in the ability for individual cells to be electrically erased and rewritten. Hence, it's not referred to as ROM (Read Only Memory).
There are other parts of an SSD that can fail other than the memory. The controller software/hardware can fail and make it so the data in the memory cells of the drive is not accessible. Some early controller software was buggy but it seems that the various mfrs have gotten the software pretty stable nowadays.
