ewarnerusa
Nov 27, 2013Nomad
I don't think the item in your first link would provide any benefit, it is for isolating a battery from a system. When you are running your 12V stuff off-grid, you need your batteries connected.
Since the stereo only begins to cut out after a couple hours, then this suggests that everything works normally when your batteries are full. Only after you have discharged them a ways do voltage drop issues occur.
I suspect that some of your other equipment is causing the voltage drop on the system, then your stereo cuts out when that happens. Probably your compressor on your fridge kicking on causing a voltage drop on the system, then your stereo picks that up and shuts down.
Try unplugging/shutting off the fridge next time you are getting intermittent operation from the stereo. See if that stops the stereo from shutting down again.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
