MNtundraRet
Nov 27, 2013Navigator
Your batteries are 12.7 volts when fully charged. Anything else is just surface charge and worth a minute or two in time.
The likely culprit causing the voltage to drop to low for the stereo is your compressor refrigerator. After a few hours your battery voltage has dropped enough to have the voltage under load needed to drop below current needed to run the stereo. The current needed to start the compressor causes a sharp drop in voltage from the batteries, causing stereo to cut out.
That's why RV's do not use compressor refrigerators. Fine for shore-power, but a game ender for camping on non-electric sites.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
