pianotuna
Nov 28, 2013Nomad III
Hi,
Measure the voltage at the connection to the stereo. Then measure the voltage at the battery. Now turn the fridge ON and do the same.
I suspect who ever installed the stereo used tiny wire with a long wire run causing lots of voltage drop. The real solution is to rewire with much thicker wire.
Adding a boost unit such as the one KD4UPL suggested would also work.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
