pianotuna
Nov 28, 2013Nomad III
Hi,
Compressor fridges do use less power than an absorption fridge when running on 120 volts AC power.
A modern absorption fridge running on propane requires up to 1.5 amps when the gas valve is open. Duty cycle is about 2:3, so they use about one amp per hour, or 24 amp-hours in a day. Converting that to watts makes the number about 288 watt-hours per day.
The nova cool draws 4.4 amps @ 12 volts. I do not know the duty cycle, but it will certainly be less than the absorption fridge. It might well use fewer watts than an absorption fridge running on propane.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
