- swphotobugExplorerI ordered the Straight Talk Hot Spot(Verizon service). Since I have an ATT phone I felt a different vendor would cover all bases in access.
Most CGs now have a version of wifi but some are very slow. We are in one now for 3 months and service is dicey. Saw the Straight Talk and figured it couldn't be any worse and the service should stay up rather than crashing several days a week. - 1985air345Explorer
swphotobug wrote:
I have an ATT phone via Straight Talk and have been happy with is service. We travel a lot and have always had service.
I am interested in the Verizon Hot Spot service, I ordered it today(Black Friday).
If you ordered it through Verizon, you'll be very happy. I had a Verizon Jetpack under contract and it worked everywhere I went.
I have heard that the Straight Talk Verizon Hotspot also works on the pre-pay network but I have not confirmed that. - swphotobugExplorerI have an ATT phone via Straight Talk and have been happy with is service. We travel a lot and have always had service.
I am interested in the Verizon Hot Spot service, I ordered it today(Black Friday). - 1985air345ExplorerStraight Talk is a real hit and miss service. Straight Talk uses four networks (AT&T, Verizon, Sprint, and T-Mobile). Look at the color of US map on the front. The agents will NOT tall you what network the phone will be on. You have to check the color of the US map.
I was VERY unhappy with a Straight Talk phone through Verizon (red map). You end up on their pre-pay network which is MUCH smaller than their contract network. For an RV'er, that smaller network doesn't work. I switched to a Straight Talk AT&T phone (blue map) and have been MUCH more satisfied. I bought an unlocked GSM phone and the Straight Talk SIM card for AT&T.
I just purchased a Straight Talk hotspot (model ZTE Z289G) with the blue map (AT&T). I'll have to see how well that works.
Straight Talk can be a great service if you understand what you are buying. If you stay in one area that has good coverage, it can be a great value. If you are mobile (RV'er), you need to do more research to avoid being disappointed. - doxiemom11Explorer IIFrom reading various comments and looking at many different plans as I run across different names to check out, it seems that they are all very limited in the data allowance for the fee , or very little data and then you are throttled. We have been researching for several months and have not found anything that is worthwhile for us without being cost prohibitive.
- Gene_GinnyExplorer
swphotobug wrote:
I think that listing on the Walmart is not really active yet. I did a search on the Walmart site and came up with the same unit twice. The $99 unit does work in most ZIP codes I enter, the $49 unit with the same description does not work in ANY ZIP code!!! It shows "out of stock online" and not available in any store. I suspect that the listing will go active on Thanksgiving or Black Friday. Both units show 288C in the description which Straight Talk does not recognize so the C seems particular to the Walmart website.
... The only problem is in the 2 zip codes I put in it would not work. ....
The Z288L is Verizon, the Z289G is AT&T and I think the Z289L is T-mobile .... as far as I can figure now. - swphotobugExplorerThere seem to be 3 models, 288L, 288C, and 289?. Walmart seems to be the only seller of these hotspots. The 288C is on sale on Black Friday for $49.99. The only problem is in the 2 zip codes I put in it would not work. Supposedly it is in stock at my local Walmart but the local zip won't work with it. Ber careful what you buy.
- reubenrayExplorerI will be watching this thread being I bought the 3G model a few months ago. It works great sometimes and sometimes I have it connected to a booster for a slow connection. I assume this has to do with where I am at. I am also assuming this will not change with a 4G model.
- amandaExplorerThere are two new ZTE Straight Talk 4G LTE Hotspots that have just become available. One is on Verizon (the Z288L), the other is on AT&T (Z289G).
Neither is currently available online. The Z289G is listed online but is indicated as "out of stock" as of today (Sunday Nov 2). click here
Both have been reported available at certain Walmart stores. I've seen the Z288L (the one on Verizon) on the shelves at a Walmart last Wednesday. Some Walmart locations will have the one on Verizon, others will have the one on AT&T depending on what part of the country you're in.
Reports I've seen online so far indicate that both are "throttled" ...in other words, are limited to speeds lower than true 4G LTE speeds. Someone has reported the Z288L is possibly "throttled" to 3.5 Mbps down and 1.5 Mbps up ...which is the same speeds that PagePlus LTE phones are limited to (PagePlus being another TracFone division as is Straight Talk). He was getting download speeds just above 3Mbps and upload speeds of just over 1Mbps. He reported his ping times being very low, however (which is good) --in the 29-40 ms range that are typical 4G LTE ping times.
The AT&T model I've heard is also "throttled" but to a lesser extent than the one on Verizon.
I'm still going to wait until I see more speed reports from those purchasing the new Straight Talk Hotspots before I buy one. I'm interested in the one that uses Verizon.
Here is some preliminary information about both ...click here. - riven1950ExplorerSorry I don't find a 4g Verizon hotspot on ST. Got a link to it?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 14, 2025
