Art_Davis's avatar
Art_Davis
Tailgater Problem
My Tailgater hangs up on the second bar of "acquiring signal". Guy at King Controls says it is not the Tailgater. Folks at dish replaced the receiver, and it set up properly. Then I disconnected the temp setup to reposition the receiver to its permanent location and---same problem. (It has been intermittent all along.)
I have tried connecting the RG6 cable from the Tailgater directly to the receiver, but no luck. I will now pick up a new coax and replace the original one to test if there is a cable problem.
Dish is now telling me to talk to King Controls again. But I do get good signal strength on all satellites and the gears are running in the Tailgater.
I'm about at wit's end. Can anyone help? Thanks.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    To get to the antenna pointing page on a VIP-211K which is stuck at 2 of 5.
    Press the STAR button (*) on your remote
    I won't tell you how much fun I had finding that out but.. It's in the manual
    Then you can look to see how strong a signal it has, if (As I suspect) it is not good, try a different spot to park the antenna.
  • We have had a tailgater for about 1 1/2 years and have enjoyed it until this trip. All of a sudden it stopped working. When tech support was called they said that the motherboard may need to be replaced which could run $150. We took it to a UPS store to have it boxed up for shipping and found out that the shipping was going to cost a little over $100. We paid right around $300 so now we're in a dilemma. We wish that we could find a local serviceman who could work on it but we've about decided that's not going to happen.
  • Last Wednesday our Tailgater went on the fritz. And now we are waiting for our Replacement Tailgater .. King Controls had DH take top off and it was not rotating correctly.
    Hubby had some medical tests, so wasn't up to sending it off in the Pre-Paid Fedex Label until yesterday .. hope the new Tailgater comes in this week.
    We do have Cable TV where we are, but are moving next month to a US Army Corps of Engineers spot in a couple of weeks. Hope the new one lasts longer or we are due to go to a VuCube or back to the old-fashioned satellite dish.
  • you guys be very careful when using wrenches on cable connections. you can actually cause problems with the connections on the box as the connections are soldered in and if you use a wrench and put too much pressure on it you will break that solder then you are really in trouble trying to get a signal.
  • We had the same problem last month, it turned out being the connector where the coax connected to the trailer. I also found out that the coax connections have to be tight, hand tight like I did with a my tripod didn't work just take a wrench and snug it up. Remember the power to the servo motors comes through the coax so it needs good solid connections.
    Denny
  • The way king controls explained it too me was that if the signal stopped during acquiring the signal is that I didn't have a clear view of southern sky to find all three satellites. But I had a problem with the tailgater and it wasn't scanning vertically and had a bad motor in it. Replaced the tailgater and all ok now. So not sure what is causing your issue!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
