- rhagfoExplorer III
6string wrote:
I'm new to dish tailgater. Does anyone know what are good signal levels to expect on the three satellites?
We love out TailGater, as it is like the old Ronco ads, Set it and forget it!!
Yes, I also us an app to see if we have clear view to the southern sky and the satellites, but after that it is all the Tailgater.
I usually place on the 5er roof so out of the way and safer. The first time we did this it was by a kitchen vent that was slightly open, we could here the dish realign for best signal when we changed channels! - BB_TXNomadSince there is no adjustment you can do with the Tailgater to improve the signal strength, just make sure that it has a clear line of sight to the satellites. And you can use a phone app to find that line of sight. Even sparse tree limbs can reduce or even block signal.
Many problems with signal strength are caused by poor internal coax cabling or coax cable connectors in the RV. If you are consistently having problems, those may need to be checked. Also buying a good quality quad shielded external coax cable to connect the Tailgater to your RV coax connector may help. - georgelesleyExplorer IIRain and dust or snow quickly degrade the signal because the dish is much smaller than a normal house size dish. (Don't ask me how I know this) I finally waxed ours to repel some rain and snow. It helped a lot.
- wa8yxmExplorer IIITHe rule is "If it works" Generally anything over half a signal bar on the receiver. But it varies from receiver to receiver. 60% is generally solid 50 may have issues.
- lj2654ExplorerI never worry about signal levels. I use an app for setting the tailgater so it is clearly lined up due south.
If it goes through the scan ok then thats all that is needed.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
