larry_barnhart's avatar
Apr 30, 2015
text to email address???
Since Verizon is giving free text messages I decided to do text messages. I would like to know if a text can be forwarded to an email address.
chevman
  • MrWizard wrote:
    you will be using internet data to send the Email
    this will NOT be FREE
    I'm not finding much info, but I can't say I agree with this, yet.
    The best way to know is to turn your phone's data OFF and try it. That will tell you for sure.
  • MrWizard wrote:
    chevman
    Only the initial text you receive will be free
    unless of course he and the recipient are both on an unlimited text plan.
    chevman
    Converting to email may use data as email does. I would check with your carrier before encurring data usage I don't want used. Know first.
  • AllegroD wrote:
    chevman
    when I send an "email" to my Verizon phone or to any Verizon phone in the format phonenumber@vtext.com it comes to the phone as a text message, not e-mail.
    chevman
    Sending to vtext ..
    Assuming you send from a pc, you are using internet data to send the msg to an internet address...Aka vtext.com same as sending to Gmail.com
    Vtext then sends a text msg to your phone number
    Forwarding to an Email address is Sending an EMAIL
    EMAIL does use internet data
    Email uses an ip. Aka internet address
    Texting protocol does not use internet protocols
    Text to a phone number from a phone is text via text protocol
    Take a text and send it to an Email address via email on the phone is using internet data
    If the text forwarding sends the msg from a vtext address to the email
    Then it might be treated as text protocol from phone to vtext and not charged
    As a test I just forwarded a text from my Verizon phone to my email address with the data turned off.
    It worked.
  • TEXT does not use DATA .. it is "SMS" short message system PROTOCOL
    you did NOT send an email
    you sent a text to vtext.com which delivered it via email to your email
    Look at the SENDING address of the email
    yes it did NOT use your phone data
    the recipient (in this case yourself) received an email
    but the sender..sent a text to vtext.com
    technically not an Email
    but yes the OP can send the msg to other peoples email
    now the question becomes, can he send it to more than one at a time
  • OP here. I will forward the text I receive to my email address and then forward it to others that would like the email.
    chevman
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
