Bumpyroad's avatar
Bumpyroad
tpms issues
on my 2011 Highlander had the tpms light come on. I didn't even know it had tpms and my mechanic said that they have been mandated for several years, WHO KNEW? :)
It first came on months back, checked the pressures all OK, so had the diagnosis that position 1 was bad. He said that "1" was left front usually but I haven't checked with Toyota for confirmation.
checked on the internet and prices ranged from $2.38 to $71.62??? with labor about 70$. I assume that is per tire and mechanic said he could change just the one. he wouldn't pull the fuse which would be option A, and option B would be to put a piece of black tape over the light.
does anybody know which is position 1 on my vehicle? is there a fuse so I can pull it? the mechanic said he couldn't do that.
any suggestions? I've driven for 60 + years without them so I can wait until I get new tires to get it replaced.
thanks
bumpy
  • Each sensor has a position number. When tires are rotated or replaced the number 1 could have moved. My spare tire also has a sensor. Make sure you check pressure in it (only on full size spares)
    You can lower pressure in a tire, determine it's number. Will have to do it with each.
    Don't forget the sensors have a battery!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
