NekkidFish's avatar
NekkidFish
TV / DVD Player Question
So, the new RV has a 39" Furrion LED HDTV ... and below that is a Jensen JRV212T player that looks like it does about everything.
We put a DVD into the Jensen, and it started playing, with the movie audio coming out of the speakers ... but, it would not play on the TV.
I pushed the 'source' button and it has the following choices:
TV
AV
Component
HDMI 1
HDMI 2
HDMI 3
USB
No matter which one I selected, it said no signal.
I can see on the side of the TV that there are no HDMI cables plugged into any of those.
I can barely see the back of the TV (it comes up from the kitchen counter) but I can see that there are various video cables hooked in back there. I pushed on all of them, and they are in tight.
I did not see any USB cable connected.
The setup: the TV comes up out of the counter. The stereo/DVD player is mounted right below the counter, and the fireplace is below that. There is no access door outside of the RV behind all of this. So, I am guessing we might have to pull out the fireplace to access the cords for the TV and stereo?
Any ideas or thoughts?
Thanks!
  • Update - I got it working!! :B
    I unscrewed the screws on the stereo, and pulled it out ... And noticed right away that two of the cables were not in tight. Pushed them in tight, put the stereo back in, and the movie played. Yay!!
    It is a stereo/MP3/CD/DVD and who knows what else player.
    Thanks everybody!! :)
  • Yep it will pull out. I pulled mine out to hook the TV speakers to the radio.
    I do have a question. Does the front of the stereo have a panel that you push on, and it flips open? Or des it have slot to put the disc into?
    If it has a slot. Then it is prolly a DVD player as well. If it has the panel that flips open. It is prolly just a radio, and CD player
  • So I had to Google to find out how to get the drawer out, and I finally got it out. But, there is just like a 4" tall opening and there is no way to get in there to do anything.
    There are four screws on the front of the stereo, one at each corner. If I remove those, do you think it will pull out?
  • sch911 wrote:
    What about access by removing the drawers to the right of the fireplace?
    Oooooh, I didn't thnk about that! I will go look!
  • What about access by removing the drawers to the right of the fireplace?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
