IAMICHABOD
Jul 27, 2013Explorer III
Does it look likeThis
If so it has a poly switch in it that will shut down for 2 minutes if there is a short and the Green light wont come on.
This PDF may help in trouble shooting the problem.
Wineguard power supply
I hooked my Jack up to it and had no problem with it as long as the green light was on.
You have to remember with the new signals that are put out now you wont get snowy picture when you are close to the signal, like the old days, just a blank or blue screen, it is all or nothing.
I had to point it toward the signal and put my TV on auto scan each time I moved location, it has worked 10 times than my old Bat Wing.
Hope This helps.
Hope This helps.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
