Bill_Satellite
Jul 27, 2013Explorer II
wa8yxm wrote:
You may (or may not) have bad termnology..
I understand that in some cases the wall plate module really is a booster, This unit is not compatable with the JACK antenna unless the wall module is a Sensar Pro.
In most cases the wall unit is only a power supply and should provide near battery voltage to the Jack
So will the Sensar Pro wall module.
While frequently called a booster, that's just not the case unless you go back to the early 90's. The wall plate is a power supply and is fully compatible with the Jack. The Sensar Pro is also a power supply with a secondary amplifier but has nothing at all to do with compatibility.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
