wa8yxm
Jul 29, 2013Explorer III
Bill.Winegard wrote:wa8yxm wrote:
You may (or may not) have bad termnology..
I understand that in some cases the wall plate module really is a booster, This unit is not compatable with the JACK antenna unless the wall module is a Sensar Pro.
In most cases the wall unit is only a power supply and should provide near battery voltage to the Jack
So will the Sensar Pro wall module.
While frequently called a booster, that's just not the case unless you go back to the early 90's. The wall plate is a power supply and is fully compatible with the Jack. The Sensar Pro is also a power supply with a secondary amplifier but has nothing at all to do with compatibility.
That is exactly what I thought I was saying.
The wall plate is a combination switch (Selects cable or Ant) and power supply for the booster which is INSIDE the antenna.
The Sensar Pro (Which I have and use) includes a second booster amp, but as you noted, that does not affect the rooftop operatonin (I simply said it would work).
I might add, the Batwing, with wingman and sensar pro is one dang hard to beat combination.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
