Bill_Satellite
Jun 26, 2016Explorer II
You would need to check to see if there is 12V power at the antenna head. Is there a light lit on the power supply (not a booster, but called that by many) when you turn it on? If not, look for a blown fuse. If there is a light, and you can get up on the roof, remove the coax from the antenna head and use a multi-meter to read the voltage inside the coax. It needs to be 12 VDC or better.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
