grizd's avatar
grizd
Tv connection
Have good potential over air signals per my jack signal meter. Unable to get over air or cable stations when I scan on menu of remote for tv. Tv works when watching movie. Suspect hdmi connection or antenna connection. Does getting movie on tv rule out hdmi connection? Called samsung, reset to factory settings, still no channels located. I am on road. Going thru Amarillo this am, any thoughts or suggestions?
  • If you are using the antenna, on the tv remote goto menu then select the antenna input, then scan channels. If on cable select cable input and scan channels.
