Ltrip's avatar
Ltrip
TV or TV antenna or ?? just quit
We are on a 3 week trip.  2 weeks into it and am now in Denver CO.  TV and systems working well until this morning.
I am in a 2018 AF 25Y.  We are using the over the air antenna.
Turned on the system; made sure the "button" was for TV (not cable); Went into the TV to do the channel scan.
Everything working fine.  Had it on a channel while we ate breakfast.
All of a sudden the image on the screen froze.  I waited a minute and tried to change the channel....The channel changed, I saw the channel number, but no program.
I re-ran the channel search.  Failed.  No channels found.
It is as if the antenna just quit.
Does the antenna have a fuse?  I have checked all the connections.  Seem OK.
???????I have not yet gone up on the roof to inspect.
Then a different, but related?, problem.  The TV is plugged into the Charging Center via a cigarette lighter plug.  That plug now has no power.  The TV wont go on.  However, in the same charging center are 2 USB ports for charging.  They have power.  I would assume The entire charging center would be on the same fuse/circuit.
Very confusing.  Any tips or suggestions would be much appreciated!!!
Cheers,
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
