Ltrip's avatar
Ltrip
TV or TV antenna or ?? just quit
We are on a 3 week trip.  2 weeks into it and am now in Denver CO.  TV and systems working well until this morning.
I am in a 2018 AF 25Y.  We are using the over the air antenna.
Turned on the system; made sure the "button" was for TV (not cable); Went into the TV to do the channel scan.
Everything working fine.  Had it on a channel while we ate breakfast.
All of a sudden the image on the screen froze.  I waited a minute and tried to change the channel....The channel changed, I saw the channel number, but no program.
I re-ran the channel search.  Failed.  No channels found.
It is as if the antenna just quit.
Does the antenna have a fuse?  I have checked all the connections.  Seem OK.
???????I have not yet gone up on the roof to inspect.
Then a different, but related?, problem.  The TV is plugged into the Charging Center via a cigarette lighter plug.  That plug now has no power.  The TV wont go on.  However, in the same charging center are 2 USB ports for charging.  They have power.  I would assume The entire charging center would be on the same fuse/circuit.
Very confusing.  Any tips or suggestions would be much appreciated!!!
Cheers,
  • Thanks.
    The cigarette plug had a fuse and it was blown. I replaced it and the TV works now.
    I will take the plate off to check for antenna fuse.
    Thanks!
  • Yes, most power supplies for the antennas has a fuse. Located behind the face plate, you must remove it from wall.
    What button are you pushing for TV? If you have a video switch, some of them must have power.
    Do you have a 120 volt cord for TV? Try it.
    Check power supply to charging station. It or the circuit should have fuse. Check by plugging in different device.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 07, 2026
