wa8yxm
Jan 20, 2021Explorer III
Ok, first you did not remove the booster you removed the power inserter.
your OTA antenna booster is in the antenna
Now if neither OTA nor Park cable come through... It is likely the wall plate. BUT...
if only one (Park cable or OTA antenna) does not work it gets a tad more complex.
One issue, though I'd be surprised if this covered both TV's at one time... Is the crimp on connectors.. A good sneeze and they come off... if they have "Slipped" a bit then the center wire might not make contact..
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 28, 2026
