dryfly
Nov 14, 2017Explorer
Gdetrailer wrote:
You should also understand that many UPS units will not and cannot work with a generator as a input source.
As far as running electronic equipment from a generator goes, should be perfectly fine for 99.9999999% of the equipment out there..
I understand, but this is a little confusing. Are you saying that it is necessary to remove the UPS when running on generator power? If the UPS may not perform on generator power, and yet the generator should supply smooth enough AC, it sounds like when generator is activated the UPS must be taken out of the circuit. What am I missing here??
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
