MEXICOWANDERER's avatar
Jun 21, 2017
USB Powering Multiple Speakers...?!?
A laptop with audio 3.5 mm and USB port for one of those USB audio gizmos.
Great.
But I have three speakers that I could power and they are made for computer use so they all have built-in amplifiers. They were a gift and a pair are JBL. Not junk.
They all have stereo type 3.5 mm plugs.
And I am hard-of-hearing with no neighbors so save loudness rants.
The laptop also has the VLC orange traffic cone gizmo which really improved the sound - equalizer wise.
Is this "do-able" or a pipe dream?
Thanks In Advance.
  • Is what doable?
    Powering your existing speakers from USB? Maybe, maybe not, there's not enough info. Do any of them run on 5V (look at the soap-on-a-rope power adapter. If any are 5 VDC and <500 mA, probably (may depend on laptop). If any are 12 VDC, you should be able to cable them into a standard 12 VDC cigar lighter outlet ("DC Outlet" in modern, politically correct, terms).
    If any speaker, a lot of the rechargeable Bluetooth speakers available recharge via USB, will run while USB powered, and also have 3.5 mm jacks. If the laptop has Bluetooth, you could even avoid the cable - those small speakers don't have enough fidelity for it to make a difference in sound.
    Or, as the title implies, do you want to power all ("multiple") speakers from USB? A single USB port, nope.
    Be clear in what you're asking.
  • PC USB output is normally limited to 500ma spec
    That means 2.5w
    There is no power on the 3.5 mm sterro Jack
    If the jbl speakers are externaly powered from another source ( not pc ) you can certainly use the audio signal to drive them, to get more sound
    I have a pair of pc speakers with built in amp, that are powered by a wall wort
    That i sometimes use
    Side note, my first job in California was at JBL, in Northridge Ca, in their then brand new facility
    Funny thing i drove by there this morning, they are doing more construction at what is now the Harmon Karden xxxx Campus
    Ok sorry, back on topic carry on
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jun 18, 2025
