MEXICOWANDERER's avatar
Dec 16, 2015
USB Wall Charger Specs Confusion
Was received as a gift. No manual no specs. Just two prongs to plug into a wall receptacle and two USB Charger ports. White. Sorta shaped like an elipse. Molded in specs give no clue except for "10-watts 2.1 amperes @ 5.1 vdc.
Has a hidden blue LED indicator light.
The 2 USB charger ports are marked
NA
A
Got me...
    NA
    A
    Got me...
    Typical run of the mill 1A PER PORT USB charger..
    10W divided by 5.1V is 1.96A and you have two ports.. Should be able to do the math from there..
    For 2A per port I would expect one that states 24W at 5.1V..
  • What's your question?
    Sounds just like a regular run of the mill USB charger. At that amperage it will probably only charge 1 iPhone or iPad, not 2.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
