darleyhavidson's avatar
May 10, 2018
Using RG-11 with Winegard Satellite???
Ok, I emailed the company (Winegard) to ask if RG-11 coax cable could be used with their Playmaker satellite. They only recommended RG-6. So, I asked if they have ever tested the system with RG-11 and they replied they had no knowledge of that.
The main reason I ask is that the manufacturer of the RG-11 indicates that the cable may not be compatible with certain satellites. And to query the satellite manufacturer first to ensure there will be no issues.
Well, I tried that to no avail. So, I ask the masses, what say you?
(FYI: I want to use aerial RG-11 coax since I have a long run (88 feet) and will be placing the cable in the trees enroute to where the satellite is positioned.)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
