darleyhavidson's avatar
May 10, 2018
Using RG-11 with Winegard Satellite???
Ok, I emailed the company (Winegard) to ask if RG-11 coax cable could be used with their Playmaker satellite. They only recommended RG-6. So, I asked if they have ever tested the system with RG-11 and they replied they had no knowledge of that.
The main reason I ask is that the manufacturer of the RG-11 indicates that the cable may not be compatible with certain satellites. And to query the satellite manufacturer first to ensure there will be no issues.
Well, I tried that to no avail. So, I ask the masses, what say you?
(FYI: I want to use aerial RG-11 coax since I have a long run (88 feet) and will be placing the cable in the trees enroute to where the satellite is positioned.)
  • Whatever coax used, it must be 75 ohm. RG-58 and LMR are 50 ohm and can not be used.
  • RG-58, RG-59, RG-11, RG-6, LMR whatever, etc. Choose. The difference for the <50 ft run in an RV is mice nuts. If you want to brag and spend money (without making any practical difference), install some Heliax hard line.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    at 1GHz RG11 nominally has about 1/2db less loss/100ft than RG6. 5.6db vs 6.1
    Now RG59 spec is 21db/100ft at 1GHz.
    now comparative losses at lower frequencies are not near as bad. but then I think the output frequency from the LNB is 950MHz -1400ish MHz.
    given that, I've had cheap pieces of RG6 that had losses near 10db in 10ft!! usually a bad termination.
    buy quality RG6 or RG11. There is lots of cheap inferior stuff out their!!
  • RG-11 will work just fine. I have used it in a number of setups. However, I would not expect any improved performance and Winegard usually specs less than 50 feet max run for their coax setups. It is highly doubtful that RG-11 would help it work if you plan to run 88 feet.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    In my research I have confirmed that top quality RG-58 beats low end RG-6
    But.... Remember Motor homes are generallyu built of LOWEST BIDDER cable
    Which is why I recommend RG-6 fOR sat. though as I said above, RG-11 will work.
    I have about a mile of RG xx in this house between the rube goldburg TV system the TS-2000 and the other radios. Assorted flavors even 50' of LMR-40.
  • fpresto wrote:
    Not all RGs are equal either. In our lab we often found that a good quality RG-58 would easily outperform a cheap RG-6.
    I assume you meant RG-59. RG-58 is 50 ohm.
  • Unless you're going a long distance I can't see much advantage in doing that. The shortest distance and the least amount of connectors is the goal to minimize signal loss.
  • I have worked with both. The major difference between RG-6 and RG-11 is cable size. RG-11 is much stiffer and thicker. It is much more difficult to work with. Unless you are making runs of 500ft or more the slight gain of RG-11 over RG-6 is probably not worth it. I am not surprised that Winegard would have no reason to test it as it is not practical to use with their systems. It is interesting to note that there is no standard for RG designations. That is a term that was used by the military back in the 40s and 50s and stood for Radio Grade. It has long been superseded by MIL-Spec. I could take any piece of wire, stamp RG-6 on and sell it as RG-6. Not all RGs are equal either. In our lab we often found that a good quality RG-58 would easily outperform a cheap RG-6.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Did a bit of research. RG-11 should work fine, It is a 75 Ohm Coax. same as RG-6, but RG-11 has lower loss per unit length so it should actually outperform RG-6 The only other possible concern would be center conductor size. And since it omes with "F" connectors I am assuming downright close.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 24, 2025
