BradW's avatar
BradW
Explorer II
Oct 31, 2019
Using Winegard Satelite Dish Far From Home???
We just got back from a trip to Yellowstone from our home in Alabama. We could never get our Winegard Roof Dome Antenna and Direct Satellite Receiver functioning properly.
I admit that this is all pretty new to us, but we did get it all to work before we left home.
Our dish system is pretty simple, just turn it on and let it find the satellite. Then we have to go through set up mode on the Direct receiver. We could never get the thing working. We tried at 3 differ locations while on the trip. They all had unobstructed views of the southern sky.
I guess we should have called Winegard or Direct help line, but we never really needed it to work to actually watch something important, we were just making sure we knew how to use it. Well obviously we didn't and it was usually late in the day when we tried and we just gave up.
My question is, since we travelled a long ways west and a long ways north, is there something we should have done differently to set up the antenna or Direct receiver to tell it we needed to look at a different satellite or whatever?
Thanks for any help,
bradw
  • Bill.Satellite wrote:
    You would need to go through the receiver setup once and only once unless you move the receiver between home and RV. If that's the case, you must go through the receiver setup before you try to have the antenna search for the satellite as it will not be able to do so with any of the home setup settings. In the RV you want to have the receiver set to 18" round and Multi-switch to allow the antenna to locate the 101 satellite.
    He's got the Trav'ler that gets all three sats with the push of a button.
  • Thanks all for the good info. Like I said, this is all new to us and we are struggling with it.
    We will go out there tomorrow and try again.
    Thanks,
    Bradw
  • You would need to go through the receiver setup once and only once unless you move the receiver between home and RV. If that's the case, you must go through the receiver setup before you try to have the antenna search for the satellite as it will not be able to do so with any of the home setup settings. In the RV you want to have the receiver set to 18" round and Multi-switch to allow the antenna to locate the 101 satellite.
    Not sure what this means. All you should have to do is turn it on.
    As the other poster stated, location doesn't matter.
  • I use the same setup. We've been all over the country with no problems, so it's not a location issue. I think the box isn't getting the sat signal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
