- MrWizardModeratorI wonder, for those of you that have problems with this form of communication, send from email to phone text,
Are you in your carriers designated coverage area ?
Or
Are you roaming,. Such as getting Verizon on Sprint tower or att on TMobile tower
Knowing this might help clarify the issue
Your phone should have and indicator, either on home screen or in settings
Also roaming can be turned of in settings/networks,
If in doubt, as a test temporarily turn off roaming , if you loose cell service, you are roaming on sn affiliate tower, not using your carrier owned tower, - Cristian123ExplorerThis is why I switched to Boost Mobile. It runs on AT&T & T-Mobile and everything works great. Moreover, I can always call the boost mobile phone number (I found it on this website https://boost-mobile.pissedconsumer.com/customer-service.html) and solve any issue within a few minutes. No regrets.
- UdicomoExplorerI just came across the same problem. Any fast solutions?
- 2oldmanExplorer II
wa8yxm wrote:
Their customer no-service is pretty much that.
There is a reason I am not a Verizon customer.. I won't bore you with the full story but ... Cuss-some-more-Service was invented by one of the companies that merged into Verizon.
What I find perplexing is, does no one else but me, the end user, see this pile of errors? I mean, they have to be created somewhere, and nobody sees them? And help links that don't work..! - 2oldmanExplorer IIThe messages are starting to work, but they're being delayed anywhere from 20 minutes to many hours. Verizon is not responding.
Getting any help at all from Google is so far, impossible. - wa8yxmExplorer IIIThank you .. Just sent myself a mobile-number@tmomail.net (MMS)
message.. Worked. fine
There is a reason I am not a Verizon customer.. I won't bore you with the full story but ... Cuss-some-more-Service was invented by one of the companies that merged into Verizon. - MrWizardModeratorI did a email text to myphonenumber@vtext.com
And it worked
I sent a test gmail email to a friend's AT&T cellphone number
(Using the info posted above)
And they received it - BarneySNomadSent a message to my Verizon/Visible number from my computer using Gmail. Message came through fine on my Android phone via text message.
Barney - 2oldmanExplorer IIIt's funny.. I can send these message to my phone, and when they don't work, get a ton of error messages back, day after day, but nobody notices.
I can go to Amazon and browse for a generator, and soon my FB page will be deluged with ads from generator sellers. - esyersExplorer
2oldman wrote:
esyers wrote:
and you may get an error message later.
I used gmail from a desktop, never got the message on my phone.
Give the man a cigar, you called it.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
