TNGW1500SE's avatar
TNGW1500SE
VPN Problem
I'm attempting to set up a VPN. Every time I try to add a Incoming Connection in Network and sharing center it will not add the icon to my adapter settings list.
I'm going into:
Change adapter settings
clicking ALT key
Then file
Then add new incoming connection
I add the user
click through the internet
IP6 is the only box unchecked
and I allow access
No incoming icon gets added.
What am I missing?????????
  • I have a VPN at my house so I can connect to my home network from outside. This includes viewing my security cameras. I have a good quality ASUS router and setup an OpenVPN connection. When setting up this connection, you have to download a config file (config.ovpn) which includes all the information and the encryption keys to let you connect. You also have to set up a login on the router. When logged in, it is just like you are connected to your home network.
  • Install the free version of TeamViewer on both computers and call it done.
    TeamViewer.com
  • are you working on the home PC or the office PC
    home is outgoing
    work will need to accept the incoming from your home PC
    and that is about as much as i know about it
    the office PC will need to be setup for file sharing
  • GordonThree wrote:
    Incoming connection - you're trying to setup your computer to allow someone else to connect in from the Internet? Typically incoming connections are handled by a router or firewall, PC's should never be directly connected to the Internet.
    What Windows are you using?
    Is this the page you're using?
    http://www.avoiderrors.net/setup-vpn-windows-10/
    Looks like a lot of steps, there may be an easier way, what are you trying to do?
    I'm using windows 7
    I'd like to able to be at home and run a program (Quickbooks) on my home PC that uses a storage file on my PC at the office.
  • Incoming connection - you're trying to setup your computer to allow someone else to connect in from the Internet? Typically incoming connections are handled by a router or firewall, PC's should never be directly connected to the Internet.
  • 2oldman wrote:
    Any help on google or youtube?
    been there,,, doing that.
    Can't find anything
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
