- Dutch_12078Explorer II
chiefneon wrote:
Howdy!
I don't have either one listed we use Maximum Signal booster and it works great. Just a suggestion to look into.
Maximum Signal
"Happy Trails"
Chiefneon
X2! Our Maximum Signal Max Amp RV has given us good cell signals in places our previous weBoost found no signal at all or a poor signal at best. And we particularly appreciate the way the Max Amp distributes the repeated signal the entire length of our coach, instead of only within 2-3 feet of the weBoost inside antenna. - chiefneonExplorerHowdy!
Maximum Signal
"Happy Trails"
Chiefneon - pianotunaNomad IIIFor best results, use an exterior antenna with the highest gain you can find. For truly long distance results get a directional antenna such as a Yagi.
I'd probably pick the WeBoost Drive 4G-M. - DarkSkySeekerExplorerI have two WeBoosts. One is permanently mounted at my house. The other is for camping. At my house I get 4 bars with the WeBoost where I'd only get a dot on my phone without it. I am so happy with the performance I bought the second one for camping so I did not have to pull the wiring out of the rafters. Initially the is a little setup to do to keep the receiver antenna away from the broadcast antenna.
- pianotunaNomad IIIHi Betsy,
Start by figuring out which frequencies you need boosted.
http://www.ubersignal.com/carriers
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,796 PostsLatest Activity: Apr 10, 2025
