RVhiker's avatar
RVhiker
Where to mount GPS
I've never before used a GPS mapping device in a vehicle, but was given a TomTom Start for Christmas. The device comes with instructions to attach it to the windshield with a mount. My tow is a 2500HD Chevy; if I mount it to the windshield at anything close to eye level it is so far away that operating the touchscreen would be quite a stretch. If I mount it to the dash instead, would it be able to get a signal from the satellites?
  • Best to just give it a try to find out if a signal will be received in any place you plan on mounting it. Simply Lay or hold it there and see how it does. Remember though it doesn't HAVE to be at eye level as you will only refer to it intermittently and almost always in metro areas, not on the highway. It's NEVER safe to try and do turn by turn with the device as that's how people drive into lakes and turn where there is no road :)
  • Never had a problem with getting a signal using a doughnut on the edge of the dash.
    FYI - a doughnut is a round plastic tray type thing fitted with a collar/ ring filled with sand (or something similar) to create weight around the ring and hold it in place. It has a smooth plastic inner surface to attach the GPS mount. - available at any big box store that carries GPS and almost all truck stops - Portable GPS Mounts at WallyWorld
    There was a recent thread about using a GPS in a Class C and possible interference from the cab over - and the replies were - no problem.
    One world of advice on using a GPS - train your DW/Navigator to use the device and functions - doing it yourself while driving at highway speed is not really a good idea. Almost as distracting to your driving as sending text messages.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 12, 2025
