- cochise49ExplorerSome parks merely re-broadcast the one DSL line that they pay for. That means, bandwidth meant for a family of 5 is now shared with 20 or more. Total bandwidth will never be more than the park pays for. One park we use has something like one T1 line coming into the park. Not sure about amount of bandwidth but, they have a rule that you can't stream netflix, etc. so as not to inhibit others use of the internet. Not sure how they would know, but frequently, I resort to our Jet Pack for email etc. Verizon LTE too expensive for netflix.
- rwbradleyExplorer
kcmoedoe wrote:
ChopperBill wrote:
Possible, but it opens an entire new can of worms. Set the throttling too low, everyone complains about speeds. Set it at an acceptable speed for basic usage, the high usage people still complain. Set it high enough for most apps but not things like streaming HD movies, then you get people who just have the movie sent to their storage devices, even if it takes several hours. Get several of these, and the system still gets overloaded, and it is actually a worse situation, because the system can't speed up when the network clears and erase the backlog. It becomes a situation like plumbing where 2/3s of a pipe is clogged, the water won't flow faster even if you open the faucet fully.
Just wondering. Is it possible for an ISP to put a block on high data use down loads in a large sharing environment?
Managing a network for a large organization with tens of thousands of users, I can say that to do traffic management properly ie block or throttle Netflix, Hulu etc, requires a number of things:
-someone who knows what they are doing as it requires a lot of fine tuning and regular adjustment as traffic patterns change
-a decent router that will do proper traffic shaping would be needed, your average Linksys, Dlink etc will not do it well and often makes it worse
-traffic management only works well when you are trying to fit 110-120% network traffic thru your internet feed. If you are trying to fit double the capacity, traffic management will do nothing as the router will tie up all of its resources trying to "fit" the traffic thru the pipe, it will have no resources left to actually send and receive the traffic. - 1492Moderator
Yes, some are already restricting bandwidth for popular streaming sites like Netflix.
If its a problem in a CG, then they need to block these popular streaming sites in their router firmware. Of course, there are some workarounds, but most will not know how anyway. It is also possible to track down CG guest using an unreasonable amount of bandwidth, and reduce their allocation. But it takes time to administer, and most CG may not want or have the available time to do so. Assuming they know how to in the first place? - wmosesExplorerMore often than not I find CG wifi less than accetpable and resort to using my phoine as a hotspot ... much faster for my needs.
- kcmoedoeExplorer
Just wondering. Is it possible for an ISP to put a block on high data use down loads in a large sharing environment? - FlatBrokeExplorer IIJust wondering. Is it possible for an ISP to put a block on high data use down loads in a large sharing environment?
- Sandia_ManExplorer IINot surprising as so many are using the internet for video/movie streaming and most RV parks just don't provide enough bandwidth. We always set-up our satellite even when park provides cable and only use internet to check e-mails or get info on area attractions.
- rwbradleyExplorerNearly every hotel I have been in, in the last few years have also suffered the same issues. This is including big chains, and locations in big cities. The WIFI is virtually unusable in the evening. The only place I have seen that did not suffer from capacity issues in the evening was Disney World.
Unfortunately for free WIFI, I think it has less to do with the rural location of many Campgrounds, and more to do with the Netflix effect. - ChooChooMan74ExplorerI found that at 4AM,I can connect and use the Internet at Normandy Farms. After 8am,fuggetaboutit.
- the_bear_IIExplorerThe park we are currently staying in uses Tengo Internet for the WiFi service. We have found that from the hours of 4PM to about 8PM the internet service is very slow.
The rest of the time it is acceptable.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
