8ntw8tn's avatar
8ntw8tn
WiFi booster
The new,small park we're in just installed WiFi. However,it's pretty weak even outside our trailer and usually unavailable inside most of the trailer. We do have an acceptable signal in the bedroom. I want to put a booster up there to make it accessible for the rest of the trailer. I'm looking at either the T-Mobile dap-1610 or the tp-link RE305. Both are really meant for home use and recommend having access to the router to press the button for the WP. That's not possible of course and the next recommendation is to use your cell phone and follow the instructions. Neither manual that I've downloaded explains that procedure. Before I spend $60 on either of these products I'd like to be sure I can set it up with the limited amount of technical knowledge I posess. Thanks.
  • Are you sure your issue is signal strength? Could it be a lack of bandwidth?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 24, 2025
