jisaiah14's avatar
jisaiah14
WIFI Light Switch
Hello everyone! Been on and off the forums for a while now, but this is my first post.
I have a 2018 Big Country 4011ERD and I am looking to add some simply smart functions to it starting with the lights. I was wondering if anyone knows of any WIFI switches that would be direct replacements for the standard light switches. If not, does anyone know of any WIFI switches that will work as replacements? I have about 6 light switches I will want to upgrade.
Thanks for any and all help in advance!
  • 2112's avatar
    2112
    Explorer II
    jisaiah14 wrote:
    https://www.rv-intelligence.com/product/pigtail-adapter/
    Would these work by any chance?
    I believe this is just a wiring adapter to the actual smart relay device
  • 2112's avatar
    2112
    Explorer II
    jisaiah14 wrote:
    I just found this one. Thinking of getting some of these since they are 2 channels and using them. Will they work with my 12v lighting?
    https://a.co/d/5A5sOQM
    That should work.
    Do you know if a ground is available at the switch? You'll have to pull one if not.
    Otherwise you'll be better off with the singles and and install them at the light fixtures
    That should work.
    One is not ran to the light switches, but there is a ground available that is ran into something else that I can tap into in the same location.
  • 2112's avatar
    2112
    Explorer II
    That will work.
    I keep harping on the ground because I wanted to install a dimmer on the bedroom light. There wasn't a ground available and pulling one would have been difficult.
  • 2112 wrote:
    That will work.
    So, is the ground wire just for dimming purposes?
  • 2112's avatar
    2112
    Explorer II
    You will need the ground to connect to the black Input wire of the controller for it to work.
    Ah, gotcha. My brother who is very knowledgeable with electrical work will be wiring it all up. I was just curious. Trying to learn as I go.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Oh I found another Wireless (key fob) light switch.. One of the two I had was kind of like this... This one has 4 circuits two are ON/OFF and two (on)/off (on) means momentary.. My plan was to use it as a remote slide out controller but alas.. I had issues (the momentary ones) The on/off would work for lights.
    https://www.allelectronics.com/item/rm-09/12-vdc-remote-control/1.html
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
