- jffnkrnExplorerOur Grand Design has outside lighting switches at the front cap by the landing fear switch and in the basement at the water hook up and dump valves. Good Luck & Be Safe ! ! !
- dpglifestyleExplorerDealer did verify that it was the switch in the bigfoot jack panel and said these lights were prone to burning out. Checked for power at lights and it is there. Hard to believe the whole strip went out a once.
- NW_ExplorerExplorerOur Lifestyle had a toggle switch for the led's in the front cap that wa mounted on the panel where the Big Foot jack control was.
- TimnJoExplorerGo to the Carriage/Lifestyle Owners Forum:
http://www.carriage-lifestyle-owners.com/index.php
Lots of great knowledgeable people who can quickly answer your question.
Tim - dpglifestyleExplorerI've searched in all the compartments and the only switch i have found turns on 2 small led lights that shine down by pin box. I am going to try and find a dealer that carried Lifestyles RV before their demise and see if anybody remembers where there was a switch. Thanks for all the idea's
- Rangerman40ExplorerMy switch for my docking lights are inside the compartment on the door side where the battery and hydraulic pump are.
- GPG52_Explorer IIOur Cougar 327RES's decorative front cap LED strip switch is right in the hallway as you come in.
BUT...
You can also activate some of the exterior lights from the remote control palm unit (it operates slides, awning, landing gear and lights)
but here is the kicker...
if you activate lights with the remote it bypass' the manual switches. Which means if you turn on with the remote; you must turn off with the remote, wall switches will not operate.
GPG - Our Redwood has a strip of LED's across the upper portion of the front cap. On the under side of the cap, next to the pinbox are 2 switches... 1 is for that strip, and the other is for the hitching up LED . .
- wing_zealotExplorerLook on the wall in the front pass through storage.
- cmeadeExplorerOur 2014 Alpine has the led strip to light up at night during hitching. The switch is in the battery compartment on the rear bulkhead.
About Fifth Wheel Group
