jisaiah14's avatar
jisaiah14
WIFI Light Switch
Hello everyone! Been on and off the forums for a while now, but this is my first post.
I have a 2018 Big Country 4011ERD and I am looking to add some simply smart functions to it starting with the lights. I was wondering if anyone knows of any WIFI switches that would be direct replacements for the standard light switches. If not, does anyone know of any WIFI switches that will work as replacements? I have about 6 light switches I will want to upgrade.
Thanks for any and all help in advance!
  • belairbrian wrote:
    If you want to use only wifi, you would leave the switch on and put the controller wither before teh switch (better) or after it (likely easier).
    If you put it before the switch, you can have the controller on but the switch would still turn them on and off (as would wifi). After the switch, would work much the same, but turning the switch off would likely require turning on the switch and turning on by wifi (the controller would loose power and would either revert to it's default state or remember last state, realy depends on the internal design of the controller).
    All the controller is is a wifi controlled switch. So you are in effect putitng two sitches in series.
    I would most likely put it after the switch as that would be easier and I could keep the switch on all the time with no issues (the RV stays hooked up to shore power anyways). Just need to find a switch that will work and one that is small enough so 5 could fit in the same compartment (or a couple of switches that could have multiple of the light switches wired into it).
  • If you want to use only wifi, you would leave the switch on and put the controller wither before teh switch (better) or after it (likely easier).
    Have you considered using light controllers vs switches.
    There are LED controllers that go between the power source and the light fixture.
    Typically operate on 5-28v. The module would be powered by the 12v to the light fixture.
    So you can put it inline between the switch and the fixture. But you will need to use LED bulbs if you aren't already.
    Here's an example.
    Ignore thw power brick as the RV 12v system repalces it.
    ***Link Removed***
    Would a controller work for the switch itself? There are roughly 15 lights going to all the switches I am wanting to make WiFi controlled.
  • Have you considered using light controllers vs switches.
    Here's an example.
    LED controllers
  • Dutch_12078 wrote:
    If this is the standard 12 volt lighting used in most RV's, that adds a different level of complexity in finding a WiFi accessible switching system. Most of the WiFi remote switches on the market are for 120 volt use and are powered by 120 volts.
    Yes it is 12v.
  • If this is the standard 12 volt lighting used in most RV's, that adds a different level of complexity in finding a WiFi accessible switching system. Most of the WiFi remote switches on the market are for 120 volt use and are powered by 120 volts.
  • austinjenna wrote:
    I guess I need to ask the very first question and that is - will you have internet and a router with you wherever you go camping? If you do then great - I think any wifi switch would work provided its able to fit into the outlet. A lot of them are big and chunky and you might not have the room for them to fit in
    I will have WIFI 24/7 as I am not moving the RV.
    The size is the issue. Standard switches will not work due to the size of them. 5 of the switches I want to replace are located on the same control/electronics panel on the bottom side of it with others (Water heater, etc) right above them.
  • I guess I need to ask the very first question and that is - will you have internet and a router with you wherever you go camping? If you do then great - I think any wifi switch would work provided its able to fit into the outlet. A lot of them are big and chunky and you might not have the room for them to fit in
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
