roy67ss's avatar
roy67ss
Wifi Repeater help
I am looking at various options and hardware for helping pick up wifi from poorly broadcast signals at many parks. I would like to connect an outdoor antenna to an indoor wireless router and be able to connect up to 4 or 5 devices wirelessly within the trailer.
Has anyone tried the Radio Labs kit? http://www.radiolabs.com/products/wireless/usb-repeater or some similar setup?
I tried a similar kit from JefaTech that was a very poor performer and do not want to make that mistake again.
I notice that the specs for antennas only refer to 802.11b and g. Is there any changes to the antenna to enable 802.11n reception or are antennas going to receive 802.11n signal ok?
  • Thanks for the replies guys,
    jhilley wrote:
    802.11n can use either 2.4GHz or 5GHz. If the RV Park only has 802.11g, that is all you are going to get. 802.11b and 802.11g use 2.4GHz only.
    My antenna question was about parks or other wifi sources that use 802.11n. Will an antenna built to 802.11b and g specs still work? I suspect it will only allow 801.11 g speed at best.
    The JefaTech setup I tried would not pickup as many hotspots as my laptop! Even with the external antenna up on my roof batwing!
    n7bsn wrote:
    FYI
    Also some parks are also requiring that the IP that accesses their network "log" in. So a simple router will NOT work on this type of network.
    The JefaTech help said this was entirely doable and only the router or cloned laptop mac address was necessary to make the park system think there was only one unit connected.
  • FYI
    More and more parks are setting up various band-width limiting systems.
    Either they slow the IPs bandwidth when it exceeds a certain amount, or they shut down the IP.
    What this means is if you are reading e-mail or lite web-surfing you see great speed.
    If you are trying to download movies or TV series, you will not.
  • I'm not a big fan of RV parks WiFi. Usually even if they have a strong WiFi signal the Bandwidth of the "pipe" they use to connect their network to the internet just is not big enough to handle how mny devices want to connect through from the campground.
    I've been fortunate so far to use WiFi sparingly, and rely on my smartphome as a hotspot when I need to connect to work.
    Not in my RV - but for a few non-profits I work with I've set up EnGenuis Bridge from a WiFi point - to the EnGenius - to a Wifi Access Point. I've considered do this for RoadAbode. Just is not a priority for our RV Lifestyle right now because what we do - works. Maybe in the Future. Anyway here's the EnGenius I'm taking about EnGenius Technologies Long Range 11n 2.4GHz Wireless Bridge/Access Point (ENH202) Maybe that would help?
  • 802.11n can use either 2.4GHz or 5GHz. If the RV Park only has 802.11g, that is all you are going to get. 802.11b and 802.11g use 2.4GHz only.
    Your experience with the Jefatech may have been where it was being used and you wouldn't see any thing better with any other device. In most RV parks, you will only be able to minimally use WiFi.
    I work with it every day, mostly under ideal conditions and it is still iffy some times.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 07, 2026
