Lenny K wrote:
OK. I'm interested. Tell me some more.
Intro bit:
Thanks for your interest. First, I not selling anything. I am retired and living in my RV full time and wanted to share with all what I have discovered. Second, it works for me and my neighbors.
Background bit:
We are located in a very rural area and the most bandwidth we can get is a 20 Mb/s DSL feed to our Router. From there the signal goes out over a Amped_Pro_AP directional antenna. Since I am located 200' from the source, my signal gets block by trees and larger RVs, etc. It's enough for checking email, online banking, surfing the web, etc., at the best of times. I was using a WiFi extender to share the signal inside my RV.
Being frustrated, I begin to investigate what options were available and that is when I discovered Powerline adapters. Now each RV is on a leg of the power grid, each with its own meter with a max of 16 RVs per leg. And the Router is isolated on its own leg. So I installed a TL-WA860RE at Power Pole #40 to receive the WiFi signal from the A P antenna with a TL-PA4010 powerline adapter and at my RV at Power Pole #33 I installed a paired TL-PA4010 powerline adapter connected with my original TL-WR700N to provide WiFi inside my RV.
Sorry for the long post but if there still be an interest, perhaps I can post some images of the setup with actual speed test,etc.
