camper_ron's avatar
camper_ron
WiFiRanger Pro
WiFiRanger pro
Is it me or is this thing a piece of junk. Bought it for $140.00 in 2011. It was problematic from the start. Now after putting it away for awhile I can not even get to the menu. Am I just to stubborn to accept this is antiquated technology?
Thanks, r0n……..:S
  • I also gave up on Wifi Ranger after a full year of pain and suffering. It now sits in a box, while my Cradlepoint MBR1400 operates perfectly. I've not touched the MBR1400 since it was powered up on April 1st.........
  • docj wrote:
    camper_ron wrote:
    WiFiRanger pro
    Thanks, r0n……..:S
    You do have one of the earlier WiFiRanger models. However, even it can be updated to the latest software. If you are unable to access it via wifi have you tried connecting to it with an Ethernet cable? The online control panel will be at the same IP address as it would be if you were accessing it via wifi.
    Yes I have tried connecting it thru the Ethernet cable using the same address, no luck thinking back I believe I did have some issues getting to the menu in the past. I also tried a different computer. Thanks for the response. I am about to just give up on it. I was originally using it to transmit my Sprint USB modem signal the up side of this product was it actually allowed me to connect it directly to this device. I now use the Sprint Hot Spot. Just wanted to increase some campground WIFI with this unit now.
    Thanks, r0n……..:?
  • I'm have Hawkingstech Smart repeater. Works great. If you have had enough of this unit.
  • camper_ron wrote:
    WiFiRanger pro
    Thanks, r0n……..:S
  • We had the WifiRanger Sky factory-installed on our DRV. The first one gave up after a few months. The new one has worked extremely well...so far.
  • I worked with the WiFi Ranger and the folks that run the company and I never could get things working well. I bought a Cradlepoint MBR95 and I have never had to touch it even once.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
