Dandy_Dan's avatar
Dandy_Dan
Windows 7 Desktop
Does anyone have any suggestions for purchasing a desktop that has Windows Home or Professional 7? I was able to find a new laptop with 7 but so far have not found anywhere to get a desktop with 7 in it. It is my understanding that Windows 8 or 8.1 won't run a lot of the programs from XP. Open for suggestions and Thanks ahead of time.
  • Gdetrailer wrote:
    If you are concerned about XP compatibility then make darned sure you order Win7 PROFESSIONAL. Only the Professional offers a free downloadable Virtual XP from MS website. In a nutshell you get XP which runs as a "virtual machine" on top of Windows 7 desktop so if you can not get your program to work with Win7 you can download and install XP.
    The above statement is a good tip. When we updated to 8.1 the only program (1) and hardware (1 printer) that was not compatible with 8.1 was also not compatible with 7.
  • Staples often advertises a Dell desktop with Win 7; I think around $499.
  • I bought a re-manufactured Dell from Walmart for my garage. They take old pc's upgrade them with a new processer and memory. Mine came with windows 7 and is amazingly fast. I think it cost a little more than $150.00.
    Dave
    Dave
    I doubt that Walmart is doing the "refurb".
    Walmart most likely is BUYING Dell factory "refurbs" and I would doubt that Dell is upgrading processor or memory from the original configuration.. Dell nor any other manufacturer gets "free" parts that they can afford to put faster processors in or more memory. Most likely those PCs came WITH those processors and memory and were off LEASES which went back to Dell, Dell then "refreshes" the OS and then runs a burn in test.
    Just buyer be aware, when manufacturers refurb a PC they only change out THE NEEDED part(s) to make it work again. This may be a hard drive, power supply, DVD drive or even a power LED AND the replacement parts themselves may be refurbs (think, refurbed HDs), if no parts are found to be bad they simply reload the OS according to the LICENSE which was originally attached to the PC.
    Keep in mind, Dell for sure DOES keep a record of EACH PC they have ever built via the "service tag" (AKA Serial number) so they know WHO the PC was originally configured for and what the configuration was.
    They do not replace everything in that box, nor do they upgrade the OS (XP to Win7 or 8) if they did load a newer OS they WILL have to pay extra for the new license and in the end the consumer would pay a higher price for that refurb..
    So, what you are getting is a USED PC which may have had one part replaced and they give you a very short warranty.. your mileage may vary on how long that PC will live..
  • There is a computer chain called MicroCenter and they sell computers with Win 7 if you want it. They make decent desktops and they have retail stores and are online for sales also. You may do better with them than with Dell.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
