- Suds12ExplorerThank you all. For $20.00 I'd rather by a card reader, if I know it will work. All other ideas welcome. I will let you know how I make out.
Happy Camping. - Suds12ExplorerTried both. No luck yet. The canon site says I don't need a driver.
Do you think something like this would work. Sorry I don't know how to make a clicky yet.Thanks for the help.
http://www.amazon.com/PixelFlash-No-Bend-Compact-SuperSpeed-Adapter/dp/B005IMFX2K/ref=sr_1_3?s=pc&ie=UTF8&qid=1398448722&sr=1-3&keywords=compact+flash+card+reader - 1492ModeratorIt appears driver support for your Canon ended with Vista. If WIN 8.1 does not recognize your camera with USB cable attached, then you can try installing the Canon 20D Vista driver and see if that works.
Or buy a USB 3/2 external card reader such as this Transcend Multi-Card Reader for CF cards, and connect to your computer via included USB cable. - camperpaulExplorer
- downtheroadExplorerHere is an update to 8.1 from Microsoft that supposedly will support your Cannon...(go to the Link and then Scroll down for the download)
Hope this helps...
LINK>>>CLICKY - Your camera should have come with a CD with the proper drivers to load? Or, I would think Windows should at least find it and treat it as an 'external drive' at the minimum.. Then, you would have to "path" your way to where the pics are.
My Windows 7 and even my old XP find all my old and new cameras just fine without any additional drivers... ;)
Sorry, I can't help with Win 8.1.. I will reject that OS for as long as I can!! :)
Mitch - Turbo_Diesel_DuExplorerI had my 8.1 dropped and reloaded Windows 7
- Suds12ExplorerCable to USB There no place I can find to put the compact flash. Some kind of Driver would be good or is there a cord I can put the card in then connect to the USB?
- HappyKayakersExplorer IIIAre you trying to upload via USB cable or memory stick? The memory stick shouldn't be a problem. The USB cable might require updated drivers.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
