ennajean's avatar
ennajean
Windows10 screen lock
I know nothing about husbands laptop so here's the problem.
He started to install Windows 10 but screen locked at 93% complete. Cannot unlock the screen. Any suggestions on how to get screen unlocked?
  • Ed_Gee wrote:
    On a hard lockup like that I find the only immediate solution is to hold the power button until the computer turns off. Wait a few seconds, turn it back on, cross your fingers and hope the process either starts over, proceeds from where it left off, or at least still works under the previous Windows version. If the problem persists after a couple of these tries then it might be necessary to have someone knowledgeable deal with it hands on.
    Thanks Ed this worked. It is now going back to previous Windows.
  • Shut it off with the button, then remove the battery. Then install the battery again and start over.
    Often, if something is locked, the glitch might remain unless you remove all power to the laptop. Battery power acts just like shore-power, and it never really shuts off completely unless you remove battery.
    I'm pretty tech-dumb, so can't tell you why - but when mine locks up for any reason, if I don't also remove the battery and reinstall it, sometimes it can't release the glitch.
  • On a hard lockup like that I find the only immediate solution is to hold the power button until the computer turns off. Wait a few seconds, turn it back on, cross your fingers and hope the process either starts over, proceeds from where it left off, or at least still works under the previous Windows version. If the problem persists after a couple of these tries then it might be necessary to have someone knowledgeable deal with it hands on.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
