jcag's avatar
jcag
Winegard satellite antenna mounting
Lets see if I can do this as succinct as possible.
1. Installing a Winegard SK-SWM3 Directv Trav'ler satellite antenna.
2. Instructions state no more that 3/16" off parallel. Said differently, the total crowning distance can not be more that 3/16". You can't (shouldn't) bolt a flat surfaced (antenna) to a curved surface (roof).
3. I'm interested to hear from others as to how they installed the Trav'ler on the crowned (Convexed) roof.
4. My hope is that someone has a solution or suggestion as to how the solved this problem. Not installing the antenna is not a option.
Thanks
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to "posting" issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
  • donn0128 wrote:
    haddy1 wrote:
    Install butyl tape under the dish, fasten the screws into the roof (don't overtighten), and seal with Dicor. It's not going anywhere.
    The OP is NOT worried about installing it. He is concerned about the slope effecting the antenna.
    If that's true, it shouldn't be a problem. These things are often installed off the center line of the roof. My Travler has no problem locking on when my coach is not level in a parking lot.
  • Another person with the same concerns : http://www.forestriverforums.com/forums/f23/installing-a-winegard-travler-on-a-36ckts-102714.html
  • Install butyl tape under the dish, fasten the screws into the roof (don't overtighten), and seal with Dicor. It's not going anywhere.
  • https://www.youtube.com/watch?v=_03Jh2Qxgkk
    Thanks
  • Not sure what RV you have, but Travlers are mounted on all sorts of roofs with no problem. Heck, you might give it a try. Using a bunch of duct tape tape the base down, mount the travler to it, hook up the 5 wire control and plug it into the controller, turn it on and see if it locks on. What have you got to loose? Have you asked Winegard yet if they have a wedge base?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 23, 2026
