pigman1's avatar
pigman1
Winegard Trav'ler Replacement
After numerous problems with our Winegard Trav'ler and unbelievably obnoxious people on the phone that call themselves "customer service reps", we gave up. Instead of purchasing another disaster we removed the piece of junk and installed a dish from RF Mogul. OMG!! What a difference. The antenna finds the necessary satellites in less than half the time the Trav'ler took on it's best days and operation is so easy it's almost magic. Press power on, press search, and it's done.
Not only that, but the antenna has the ability to tune all the way down to the horizon, regardless of your latitude. The Winegard would not tune below 18 degrees above the horizon. This effectively eliminated reception in the northern reaches, such as Alaska. We've spent 8 summers in Valdez, and unless I went to extraordinary measures, the Winegard was useless up here (we're in Valdez now). This year I turned the Mogul on and in less than 4 minutes I was watching DirectTV in very heavy cloud cover with occasional showers.
I purchased the antenna from Don at Precise Satellite in Florida. He will install or send you a unit for you to install. I did it myself as I'd installed two other Trav'lers. The R F Mogul is lighter and much easier to handle, but is very stiff and strong. The install does require new wiring, so be prepared to punch a new roof hole or run it down a refer vent.
For anyone interested in a first class product with replaceable parts (unlike Winegard) and super customer service, contact Don at Precise Satellite or Royal at R F Mogul direct.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
