pigman1's avatar
pigman1
Winegard Trav'ler Replacement
After numerous problems with our Winegard Trav'ler and unbelievably obnoxious people on the phone that call themselves "customer service reps", we gave up. Instead of purchasing another disaster we removed the piece of junk and installed a dish from RF Mogul. OMG!! What a difference. The antenna finds the necessary satellites in less than half the time the Trav'ler took on it's best days and operation is so easy it's almost magic. Press power on, press search, and it's done.
Not only that, but the antenna has the ability to tune all the way down to the horizon, regardless of your latitude. The Winegard would not tune below 18 degrees above the horizon. This effectively eliminated reception in the northern reaches, such as Alaska. We've spent 8 summers in Valdez, and unless I went to extraordinary measures, the Winegard was useless up here (we're in Valdez now). This year I turned the Mogul on and in less than 4 minutes I was watching DirectTV in very heavy cloud cover with occasional showers.
I purchased the antenna from Don at Precise Satellite in Florida. He will install or send you a unit for you to install. I did it myself as I'd installed two other Trav'lers. The R F Mogul is lighter and much easier to handle, but is very stiff and strong. The install does require new wiring, so be prepared to punch a new roof hole or run it down a refer vent.
For anyone interested in a first class product with replaceable parts (unlike Winegard) and super customer service, contact Don at Precise Satellite or Royal at R F Mogul direct.
  • My 5+ YO Trav'ler still works perfectly and I have had no problems and I have not been required to do even 1 software update. I wonder if RF Mogul can claim the same.
    Understand that RF Mogul is run by the same folks who ran MotoSAT until MotoSAT went broke. It's a great niche product and if you hate Winegard then you can jump right on the RF Mogul train. You just have to be handy if you have a problem as the dealer network is very, very thin. The factory folks will walk you through solutions, send parts and do what they can, but you really need to be very self sufficient if you do encounter problems.
  • TechWriter wrote:
    Can your RF Mogul also acquire Eastern Arc sats like the Travler can?
    If you're a DIYer, you can buy a DISH RF Mogul here.
    I just exchanged email with them. The answer was “no”.
    They also said that while they have interchangeable LNB assemblies for different providers, 61.5 is too far off center to fold properly so no EA LNB assembly option.
  • I dont blame you. Over 2 thousand dollars in repairs in 12 years is just plane horrible. Winegard has to be one of the worst when it comes to customer service.
  • Can your RF Mogul also acquire Eastern Arc sats like the Travler can?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 24, 2025
