Tom_M1's avatar
Tom_M1
Wingard Batwing antenna rotation
The Winegard Sensar "Batwing" TV antenna can not be rotated a full 360°. There is about a 10° dead spot and of course sometimes that's exactly where one needs to position the antenna.
Can the base be modified to allow a full 360° rotation?
  • I checked out my antenna and there is a stop that can be cut off. This stop is opposite the two ears that the arms stow into. If I cut off this stop, I'll have to make sure to remember which direction to turn the antenna so I don't twist off the coax!!! With my memory what it is, this could be a major problem.
    The dead zone usually isn't a problem, but it happens more often then I would like.
  • Don't think so. Seems to be a rare occurrence that the best spot is in the "dead zone".
  • YES....you can go up on roof and cut off the ears on base plate...they're just on there to align/hold antenna arms in place for travel and to stop antenna from full rotation so that antenna cable doesn't get twisted around arms and ripped out of antenna head
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
