stahrmcgee's avatar
stahrmcgee
Wingman... Removed.
There was a lot of bragging going on about the Wingman at the campsites I was staying at and when we got the new camper, we got one and after a fer camps we installed it. I pulled it off after the 2nd camp(on a 5 camp run) and tried to draw in the channels again. Short answer on my experience: Ours was better without the Wingman. With it on, we got 3-5 channels of moderate signal quality. Without it, we got between 15-18 channels that were all watchable. So. I did a little reading, yes, I should have prior, but I didn't, and I found out that it makes the antennae directional instead of how it is out right off the lot.
Has anyone else had the same experience?
  • I use a Jack antenna so I don't have a dog in this fight but I thought the Wingman addon only worked on Winegard antennas. Not all batwings are Winegards. Are you certain you have a Winegard? Forest River website didn't specify what type of antenna was on the TT.
  • My Wingman made a HUGE difference. Many more channels. Many time, when staying one night, I don't even have raise it.
  • The Winegard crank up antenna is directional. Head needs to be aimed at transponder tower to receive available channels....VHF (2-13) & UHF (14-51)
    The Wingman helps pull in UHF channels (14-51)
    Adding the wingman to our antenna helped alot.
    We use different websites to find the towers
    DTV Reception
    TV Fool
    Antenna Web
    Then aim the antenna towards the tower and scan for available channels
    No such thing as a digital antenna......digital signals can be picked up with a coat hanger provided the tv tuners are digital
    Digital is all or nothing unlike analog where the signal would get snowy as signal level is reduced.
  • You could be right. I hadn't thought of that. Thanks for the response though.
  • Yes and no....in our case the Wingman helped a LOT. Pulled in 32 channels camping this past weekend. Between the Wingman and the new SensarPro wall plate amplifier, our ability to track digital signals is MUCH better.
    I think the difference may be in the OEM antennae. Our RV is a 2008 model built in 2007 and before digital broadcast became as prevalent as it is now. We needed the Wingman to help our antenna receive more digital signals. Your RV is a lot newer and the Winegard unit that came OEM probably has digital capabilities built in already, so the Wingman may have actually hampered it. Sounds like it was cancelling out the digital signals on yours so you only got the analog signals.
    From what I have read, digital signals are not as directional as the old analog signals, so we do a lot less turning of the antenna that we had to prior to the Wingman. We also get much better reception with our new TVs that have digital tuners built in.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
