BurbMan wrote:
...We needed the Wingman to help our antenna receive more digital signals. Your RV is a lot newer and the Winegard unit that came OEM probably has digital capabilities built in already, so the Wingman may have actually hampered it. From what I have read, digital signals are not as directional as the old analog signals, so we do a lot less turning of the antenna that we had to prior to the Wingman. We also get much better reception with our new TVs that have digital tuners built in.
there is no such thing as a digital antenna. the frequencies being used by TV broadcasters are the same as those used for analog transmissions. the TV receiver, not the antenna, is what decodes or displays the picture.
a digital signal is no more or no less directional than an analog signal. some TV signals may be intentionally directed in a less-than-Omni-directional pattern. this could be to protect another nearby broadcaster, to service a particular population group, etc. but with everything else being equal a UHF signal will generally not travel as far as a VHF signal. and digital signals are either there or not. in the old analog days a picture would get progressively weaker the farther away you were from the transmission point until it just faded away. we called this 'snow' as in a snowy picture. think of a gently curving graph.
a digital signal is made up of zeros and ones. if the signal is there you'll get a picture, if not you won't. no snow. no weakness. just nothing. the graph would look like a sharp right angle.
the typical RV antenna is located what, 12-15 feet off the ground? and we're frequently out in the boonies, with lots of terrain obstructions (trees, hills, mountains, etc). shorter ranges (UHF), a signal that does not fade, antennas close to the ground and ground obstacles. it's no wonder RVers have trouble receiving a watchable TV signal.
and while we're at it just like there is also no such thing as a digital antenna there is also no such thing as a high-definition antenna or an antenna "optimized" for high-def. both are functions of the receiver in the TV.
