pianotuna
Mar 03, 2019Nomad III
With respect,
Amp-hour counters don't give an accurate level. They are better than a volt meter.
deltabravo wrote:The ugly duckling wrote:
I use the Victron BMV monitor. Works great and with a Bluetooth dongle you can monitor your battery from your phone.
I'm going to to the same.
To the OP, what you really need is an AMP HOUR monitor such as the Xantrex LinkLite / LinkPro or the Victron BMV712, or a Trimetric amp hour monitor.
Anything else is not going to give an accurate level of charge on your batteries.
The product you linked just looks at voltage and then lights up a corresponding number of bars in a bar graph, which is just a glorified volt meter.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
