joebedford
Jun 25, 2015Nomad III
I have a 5-year old router that I use for wired and wireless connections IN ADDITION to the modem (that also provides wired and wifi ports) provided by my ISP (not IP).
If your modem is so old that it can only do 802.11b and not 802.11n, I would chuck it because of low speed.
The one thing that somebody mentioned and I'm not sure if you caught it is that the router will have to connect to the modem from your ISP via cable. There is no easy way to make it connect to your wifi modem via, well, wifi.
You can configure the router and the modem to use the same SSID so you can walk from one part of the house to the other and your device will switch connections seamlessly (but it's a bit technical to hook up).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
