8ntw8tn's avatar
8ntw8tn
wireless router/internet question
I'll apologize now if I make this too long. Hopefully it will at least be clear if not concise.
I want to add a wireless security camera system to my house. One of the systems I'm looking at is dlink; specifically, three dlink 942l cameras. Cost is one of the factors of course.
This type of arrangement requires a wireless router, of course, and I have a modem/router supplied by my IP that is (finally) working quite well with the exception that its signal does not appear to be quite as strong as my old Linksys. I make this claim because my iPhone loses the wireless signal soon after leaving the house and with my old router it kept the signal at least an additional 50-75 feet further.
The distance from the router to at least one of the proposed camera locations is about 50 feet and it is not line of sight; several intervening walls.
I have a separate connection inside the house for internet. (I don't understand the technical parts to this, I just know that when we were having intermittent connection problems the phone technician somehow split the signal and I now have separate connections for phone and internet. He also replaced the old modem (we'd been having connection problems since that modem had been installed) with the present modem/router, making my old Linksys router an unneeded paperweight. The result was that my internet now works quite well. I'm sure it was the old modem because all I had to do was unplug the modem from power for a couple of minutes, plug it back in, and it was good for another week or 10 days.
Is there any way I can connect my old Linksys router to my internet and use it as the link to the dlink cameras (or whatever system I happen to end up with)? Thanks for the replies.
  • sherlock62 wrote:
    Wondering why you would even consider keeping your "old Linksys" or the router provided by the IP. Buy yourself a top notch router, then add the surveillance system. A very good router and a high speed internet connection from your IP, are going to be the keys to your surveillance set-up performing optimally.
    X2
  • wa8yxm wrote:
    If it does not find a vintage Linksys WGA-54G (how I do it) this is, technically a MODEM, only its not a cable modem, It's not a dial up modem, Its not a DSL modem. it is a WI-FI Modem.
    Maybe I am just thick headed, but this sentence makes absolutely no sense to me. If there is no cable, telephone or DSL signal to process (modulate/demodulate), there is no modem involved. How does this relate to the OP's question (other than your first sentence that does relate)?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yes... if the Supplied "Wireless router" has device ports (most do) just plug it in.
    ISP supplied router---Wi-Fi >>><<>><<
    There are some considreations.. Change the 3rd Octed in the IP address of the 2nd router so they are NOT the same
    IE 182.168.1.1 (router #1) Make 2nd router 192.168.5.1 or some such.
    If you can not find a WGA,, I got a product on clarance at Wal-Mart.. TP-LINK The one I have is physically different but..
    Range Extender
  • Wondering why you would even consider keeping your "old Linksys" or the router provided by the IP. Buy yourself a top notch router, then add the surveillance system. A very good router and a high speed internet connection from your IP, are going to be the keys to your surveillance set-up performing optimally.
